Steven36
May 03, 2019Aspirant
Orbi RBR50 1 second delay for DNS lookup
Hi, I am running an Orbi RBR50 with 2 satellites and software V2.3.1.48. Whenever there is a DNS lookup through the Orbi router it adds a 1 second delay, measured using
"time dig www.bbc.co.uk". T...
ekhalil
May 03, 2019Master
When I try the command "time dig www.bbc.co.uk" I get the following:
;; Query time: 8 msec
;; SERVER: 192.168.1.1#53(192.168.1.1)
;; WHEN: Fri May 03 22:13:00 CEST 2019
;; MSG SIZE rcvd: 297
real 0m0.047s
user 0m0.006s
sys 0m0.024s
Are you using your ISP DNS server? Have you tried to change the DNS settings in Orbi to e.g. Googles DNS servers?
- Steven36May 04, 2019Aspirant
Hi,
Thanks for the reply. I tried changing the DNS settings to Google servers. No change. I also did a reset of the Orbi settings when I did the last software update and manually entered in the settings, with no change in the result.
/ Steven
