Steven36
May 03, 2019Aspirant
Orbi RBR50 1 second delay for DNS lookup
Hi, I am running an Orbi RBR50 with 2 satellites and software V2.3.1.48. Whenever there is a DNS lookup through the Orbi router it adds a 1 second delay, measured using
"time dig www.bbc.co.uk". T...
ekhalil
May 03, 2019Master
When I try the command "time dig www.bbc.co.uk" I get the following:
;; Query time: 8 msec
;; SERVER: 192.168.1.1#53(192.168.1.1)
;; WHEN: Fri May 03 22:13:00 CEST 2019
;; MSG SIZE rcvd: 297
real 0m0.047s
user 0m0.006s
sys 0m0.024s
Are you using your ISP DNS server? Have you tried to change the DNS settings in Orbi to e.g. Googles DNS servers?
Steven36
May 04, 2019Aspirant
Hi,
Thanks for the reply. I tried changing the DNS settings to Google servers. No change. I also did a reset of the Orbi settings when I did the last software update and manually entered in the settings, with no change in the result.
/ Steven
