electronics18
Dec 08, 2017Star
Orbi RBR50 2.1.1.12 Wifi Password issue
I am in access point mode and I updated to the latest firmware (2.1.1.12) ealier in the week and everything seemed fine, then all of a sudden last night none of my devices would connect to the wifi s...
electronics18
Dec 11, 2017Star
Yes I responded to him as well, it is definitly a $ issue as pointed out in the reddit thread and apparently it existed in 2.0.0.76 as well as when I downgraded I had the same issue, only difference is when it reboots it doesn't truncate everytthing after the $. I still cant save the password though unless I use the mobile app. Hopefully someone from Orbi sees this and gets it fixed in the next firmware.
DarrenM
Dec 12, 2017Sr. NETGEAR Moderator
Are you using special characters with that long password? I will check if it is limited to a certain character length.
