theoak
Aug 28, 2020Luminary
Orbi RBR50 2.7.0.70 is "out"
Heard reports that this was pushed to some users.
It is available at the usual links.
Like 2.5.2.4 there are no release notes.
Orbi RBR50 support site still claims 2.5.1.16 as the official ver...
Aug 28, 2020Guru - Experienced User
For users, this are not official user links either. Only used by the Orbi system. Users should be aware. IF it's not on NG official download site, then it's not officially released. Use at your own risk.
- TbstephAug 28, 2020Star
2.7.0.70 appeared as an update on my IOS Orbi app this morning. As others have mentioned I found nothing about this firmware release on Netgear's website.
- MstrbigAug 28, 2020Master
Tbsteph wrote:2.7.0.70 appeared as an update on my IOS Orbi app this morning. As others have mentioned I found nothing about this firmware release on Netgear's website.
Looking at the filename of the zip files, this firmware is meant for RBK53 V2 model.
So they are meant for RBR50V2 router and RBS50V2 Satellite.
It may cause issues if trying to install on a V1 version.
However the official downlaod site still shows 2.5.1.16
For those that may be confused about what version they have, the V1 has USB ports, the V2 does NOT.
- CrimpOnAug 28, 2020Guru - Experienced User
Mstrbig wrote:
Looking at the filename of the zip files, this firmware is meant for RBK53 V2 model.So they are meant for RBR50V2 router and RBS50V2 Satellite.
ALL of the RBR50 firmware files that I have downloaded begin with "RBR50-V2" and installed just fine on my "V1" router.
I think the "V" stands for "firmware version"
I continue to be amazed that individuals are able to release software revisions with pretty comprehensive "release notes", but Netgear cannot manage it. Both the V1 and V2 Orbi support pages continue to state that V2.5.1.16 is the most recent firmware, even though later versions appear on Netgear download sites and numerous users have posted about being notified of (or automatically getting) newer firmware.
