theoak
Aug 28, 2020Luminary
Orbi RBR50 2.7.0.70 is "out"
Heard reports that this was pushed to some users.
It is available at the usual links.
Like 2.5.2.4 there are no release notes.
Orbi RBR50 support site still claims 2.5.1.16 as the official ver...
Richys
Aug 31, 2020Guide
Thanks re pwr off etc. I do always do that but made no difference. But for those interested, after rolling back to 16 firmware, which required new setup, several days later the 70 update showed on the app. I have just hit update ( couldn't resist) , updated very quickly, app, Ui, shows all correct info. That was with no power off. Since done the pwr off anyway, all still good. Device's are all correct also.
Maybe at last all sorted..
Aug 31, 2020Guru - Experienced User
FYI, I got this from a forum moderator:
"The FW v2.7.0.70 is for users that did not have CircleV1 activated. If user activated CircleV1 then they would get FW v2.5.2.4 update if not then they'll get v2.7.0.70. The team is planning to post first the v70 FW on our support site but no ETA provided."
Stay tuned.
- mrfrancAug 31, 2020Apprentice
I'm using Circle1 and, as you can see on the atached picture, my Orbi version is 2.7.0.70. Everything is working fine, so far. If it changes i will let you know.
