theoak
Aug 28, 2020Luminary
Orbi RBR50 2.7.0.70 is "out"
Heard reports that this was pushed to some users.
It is available at the usual links.
Like 2.5.2.4 there are no release notes.
Orbi RBR50 support site still claims 2.5.1.16 as the official ver...
jsalva
Sep 25, 2020Tutor
I just udpated to 2.7.0.70 on my RBK50 V1 (RBR50 and RBS50), the FW reseted my admin password I was able to reset the password since i had enable that option on the router setting long time ago. Besides that the FW looks pretty stable so far i guess will have to wait and see. I did the process entire manually since neither the iOS app or the web client was showing any udpates options. I'm not in the US but I used the 2.7.0.70 version anyways and I'm not a circle or user either.
I have to say that i cant believe how difficult is for us user to try to understad adecuate FW udpate process for diferrent versions of our ORBI system, this should be an automatic process for us all even transparent by default and with the working option of disabling auto updates.
I cant believe what a poor FW udpate and information support netgear profides to this $400+ USD device.
I wish they fix this, but honestly if they have not by now i'm sure they wont...
Sep 25, 2020Guru - Experienced User
Been 3+ years and counting. :smileyembarrassed:
