AdamGar
Nov 17, 2018Aspirant
Orbi RBR50 404 Not Found
My Frintier wireless router is connected to my Orbi via ethernet. If I connect directly to my router Wi-Fi I have no issues. If I connect to Orbi some websites give me a 404 page not found error.
Nov 17, 2018Guru - Experienced User
What FW is currently loaded?
FYI, Modem Combo Units:
Couple of options,
1. Configure the modem for transparent bridge mode. Then use the Orbi router in router mode. You'll need to contact the ISP for help and information in regards to the modem being bridged correctly.
2. If you can't bridge the modem, disable ALL wifi radios on the modem, configure the modems DMZ for the IP address the Orbi router gets from the modem. Then you can use the Orbi router in Router mode.
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router
- AdamGarNov 17, 2018AspirantThanks. I’ll give this a try.
- FURRYe38Nov 17, 2018Guru - Experienced User
Let us know how it goes...
- KerryBastowFeb 21, 2019Guide
I have the same problem as mentioned above but I am a bit tech naiive and I do not know how to check the things you have suggested.
Regards
Kerry
- ekhalilFeb 21, 2019MasterA simple and quick way to test if you have double NAT is using traceroute.
Please open a Command Prompt on any computer attached to Orbi and type:
> tracert 8.8.8.8
Look at the result printout, If you see two private IP addresses listed in the first two hops then you have double NAT. If you see only one private address and the second hop shows a public address, then you’re all good. :)
Private IP addresses are usually something like 192.168.x.x or 10.x.x.x.- KerryBastowFeb 21, 2019Guide
This is what I got
- FURRYe38Feb 21, 2019Guru - Experienced User
What is the Mfr and model# of the ISP modem the NG router is connected too?Modem Combo Units:
This would be a double NAT condition which isn't recommended. Couple of options,
Regards
Kerry
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
