AdamGar
Nov 17, 2018Aspirant
Orbi RBR50 404 Not Found
My Frintier wireless router is connected to my Orbi via ethernet. If I connect directly to my router Wi-Fi I have no issues. If I connect to Orbi some websites give me a 404 page not found error.
Nov 17, 2018Guru - Experienced User
What FW is currently loaded?
FYI, Modem Combo Units:
Couple of options,
1. Configure the modem for transparent bridge mode. Then use the Orbi router in router mode. You'll need to contact the ISP for help and information in regards to the modem being bridged correctly.
2. If you can't bridge the modem, disable ALL wifi radios on the modem, configure the modems DMZ for the IP address the Orbi router gets from the modem. Then you can use the Orbi router in Router mode.
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router
