AdamGar
Nov 17, 2018Aspirant
Orbi RBR50 404 Not Found
My Frintier wireless router is connected to my Orbi via ethernet. If I connect directly to my router Wi-Fi I have no issues. If I connect to Orbi some websites give me a 404 page not found error.
KerryBastow
Mar 01, 2019Guide
Sorry, can I ask another question?
I noticed on the Orbi webpage that there is a guest login, well I have an Airbnb so would like that facility.
How do I set it up?
Thanks
ekhalil
Mar 01, 2019Master
How do I set it up?
You can set the Gues Network as follows, go to the menu as below, and then choose a guest network name and password, click Apply and you will be done!
- KerryBastowMar 02, 2019Guide
Thank you so much - for all your help and patience :) - ekhalilMar 02, 2019MasterYou are most welcome. :)
