pmprather
May 14, 2020Aspirant
Orbi RBR50 ac 3000 is limiting 1GB downstream from Spectrum router to 500mbps in Orbi App Speed Test
Orbi RBR50 v2 mesh system with 2 satellites Firmware Version V2.3.5.30 I just upgraded to Spectrum Lightning Hi Speed Internet with 940.95 mbps Down and 41.60 mbps up measured today by Spectr...
May 14, 2020Guru - Experienced User
The built in speedtest app isn't the best. half the time it picks the wrong server to test off.
Also, make sure you test with several sites because not all speedtest sites or even the server on those sites can saturate gigabit.
try speedtest.net, dslreports.com, fast.com
Also, make sure the device you test on is hardwired into the orbi.
I have that same orbi and its can hit gigabit speeds.
Btw, the orbi isn't on the current firmwre. 2.5.1.16 is the current orbi rbr50 firmware.
and what modem are you using?
- pmpratherMay 14, 2020Aspirant
Using the Spectrum "No Brand Listed" modem model # E31T2V1
I believe it is the newer one with the Broadcom chip, as there appeared to be 4 manufacturers of it
- FURRYe38May 14, 2020Guru - Experienced User
Armor, Circle apps enabled?
What happens if you directly connect your wired PC to the modem? Speeds good here?
- plemansMay 14, 2020Guru - Experienced User
Once you get it updated, try a facotry reset. Then during the re-install leave traffic monitoring, access control, qos, parental controls, armor all deactivated.
Bacially, once its reset, setup your wireless and internet connection and test it.
You can also hardwire into the modem to ensure you're getting full speeds.
Yes Armor not parental controls.....Great ideas...I will give it all a go once I wrap up work here...I really appreciate it..I will post back this evening with results....
plemans wrote:Once you get it updated, try a facotry reset. Then during the re-install leave traffic monitoring, access control, qos, parental controls, armor all deactivated.
