pmprather
May 14, 2020Aspirant
Orbi RBR50 ac 3000 is limiting 1GB downstream from Spectrum router to 500mbps in Orbi App Speed Test
Orbi RBR50 v2 mesh system with 2 satellites Firmware Version V2.3.5.30 I just upgraded to Spectrum Lightning Hi Speed Internet with 940.95 mbps Down and 41.60 mbps up measured today by Spectr...
pmprather
Thank you very much for the time to answer. I have also run speedtest.net as well as spectrums speedtest, hardwired out of the Orbi to my dell laptop. the results were similar to the Orbi app with approx 490 down and 40 up.
The unusual part is that the technician on his plug in device was able to pull full speeds hardwired out of the Orbi over ethernet.
I will look to update the firmware, that could be the issue?
Jetdrive
May 14, 2020Luminary
If the tech was able to plug in his laptop and get good speeds but your laptop does not it would point to your laptop as the bottleneck. Try another computer and/or make sure your laptop is up-to-date with drivers and OS updates.
Quote: "The unusual part is that the technician on his plug in device was able to pull full speeds hardwired out of the Orbi over ethernet."
Also I would suggest you not use browser based speedtests. Download a dedicated speedtest app and run that.
