floredo1
May 01, 2019Aspirant
Orbi RBR50 AC300 slows down my internet
I upgraded my internet speed and Modem. when i connect directly to my Netgear Modem CM700, i am down loading at speeds of 300Mbps. I connected my Orbi router to netgear modem. Now my download speeds...
May 01, 2019Guru - Experienced User
Have you checked your cables that you're using? You're dropping just below that 100 mbps mark like your only using a 10/100 connection.
And I know we recommend checking speeds over a hardwired connection. Have you tested with any other hard wired (speeds) and wifi devices?
What firmware are you on?
- floredo1May 01, 2019Aspirant
brand new cables cat 7 ethernet. i connectly directly to modem with mac mini and also laptop downloaded at 300Mbps. i tried several other devices on wifi when connected to Orbi still slows down to 93Mbps. Router FW V2.3.1.48
- plemansMay 01, 2019Guru - Experienced User
Are there any other devices connect? (managed, unmanaged switches, etc)
You stated you performed a factory reset on the Orbi?
Was the orbi ever getting faster than 100 mbps?
If you test lan to lan (laptop-orbi-mac) what speeds do you achieve?
What speedtest site are you using?
- floredo1May 02, 2019Aspirant
i had everything unpugged, no additional switches. prior to factory reseting my Orbi, i was not downloading over 100Mbps. at the time i was only paying for Comcast internet speed of 76Mbps, but now i upgraded my modem and internet speed. When i do connect LAN ethernet cable from Mac mini, Laptop to Orbie, i still down load at only 93Mbps. But if i dont connect to the Orbi and just go directly Modem to Mac mini or laptop, i download at 300Mbps. i have used multiple speed test sites. speakeasy, speedtest, xfinity comcast,netspot.
