floredo1
May 01, 2019Aspirant
Orbi RBR50 AC300 slows down my internet
I upgraded my internet speed and Modem. when i connect directly to my Netgear Modem CM700, i am down loading at speeds of 300Mbps. I connected my Orbi router to netgear modem. Now my download speeds...
floredo1
May 02, 2019Aspirant
i had everything unpugged, no additional switches. prior to factory reseting my Orbi, i was not downloading over 100Mbps. at the time i was only paying for Comcast internet speed of 76Mbps, but now i upgraded my modem and internet speed. When i do connect LAN ethernet cable from Mac mini, Laptop to Orbie, i still down load at only 93Mbps. But if i dont connect to the Orbi and just go directly Modem to Mac mini or laptop, i download at 300Mbps. i have used multiple speed test sites. speakeasy, speedtest, xfinity comcast,netspot.
May 02, 2019Guru - Experienced User
I'd try downgrading doing a hard reset (hold reset button7-10 seconds), downgrading the firmware to an earlier version, reset the device again after the downgrade. . Then try your speedtesting. It'll reset back to the most current version due to the auto update.
If this doesn't work, I'd contact support as it sounds like you're connection is only connect at 10/100 and not 10/100/1000.
- plemansMay 02, 2019Guru - Experienced User
Usually the problem like this turns to be a cable. Do you have a pair of different ethernet cables to try? Just to rule out it being a cable issue?
