grandad2944
Nov 29, 2020Tutor
Orbi RBR50 AC3000 System - Cannot access online Orbi Settings
Today, for the first time, I was not able to access the online Orbi network to review and or change settings on my router and or satellite. I have accessed this site many times before with no iss...
grandad2944
Nov 30, 2020Tutor
I use the router login 192.168.1.1. For some reason, historically, I had problems logging in without using the IP Address. I have firmware version 2.6.1.40. I have attached a screenshot as you requested. Again, thanks for your continued interest. Hopefully, you have some further thoughts.
Nov 30, 2020Guru - Experienced User
When you attach them as photos, a moderator has to approve them. If you click "choose file" and attach them that route, then I can download them right away.
If you're in the US, there's a newer firmware. You could try that version
- grandad2944Nov 30, 2020Tutor
OK, sorry about that - don't use this a lot - hopefully, you can access this now. Anyway, I was aware of a newer version of the firmware, that is why I was trying to log in to begin with. Again, thanks for your time. Stay Safe in this crazy world.
- plemansNov 30, 2020Guru - Experienced User
your screenshot shows you're on version 2.5.2.4 of the firmware.
I'd try upgrading it first. See if that fixes it. If it doesn't. try a simple factory reset and reinstall.
You stay safe as well. Who would have ever thought we'd be in this situation
- FURRYe38Jan 31, 2021Guru - Experienced User
Also be sure to select "Never Remind Me Again" on the blue Armor popup window.
