BeyondSeek
Dec 18, 2019Aspirant
Orbi RBR50 AC3000. Version V2.4.12.869. Firmware V2.3.5.30. Is it will make speed down?
Hi , About my Orbi router have something wrong, few days before my router connet to modem, the speed is 300Mbps up/down. But dont know why today is become 100Mbps only, and i try connect directl...
Dec 19, 2019Guru - Experienced User
I would update to v2.5.1.8 FW on the RBS first then the RBR. Factory reset the RBR and setup from scratch.
My RBK50 was updated manually and reset and working well on a 1Gb ISP service.
BeyondSeek wrote:Hi ,
About my Orbi router have something wrong, few days before my router connet to modem, the speed is 300Mbps up/down. But dont know why today is become 100Mbps only, and i try connect directly to the modem, the speed is still there 300Mbps....
i didn't do any setting of my router with in this few days too, it should all the same......
Any one know what was happend to my Orbi router ? or any one know anything will cause my router become like this??i had try to restart router / modem and also sync it ..... but now work for it.
BeyondSeek
Jan 14, 2020Aspirant
Hi , sorry for late reply @@. Busy work and just back from vacation hehe.
Anyway, my speed from Orbi router still the same 100Mbps only. I was update my FW to v2.5.1.8 already...
The internet provider is in Philippine (Asia). Web : www.convergeict.com/fiberx/fiber-extreme
Plan : XTREME 4500
And my modem as below jpg file. Huawei.
Do you have any idea for it?
Thanks and Regards,
Seek
Plan : XTREME 4500
Thanks and Regards,
Seek
- FURRYe38Jan 15, 2020Guru - Experienced User
Your ONT already has a built in router and wifi. This would be a double NAT condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktopI recommend option #3.
