BeyondSeek
Dec 18, 2019Aspirant
Orbi RBR50 AC3000. Version V2.4.12.869. Firmware V2.3.5.30. Is it will make speed down?
Hi , About my Orbi router have something wrong, few days before my router connet to modem, the speed is 300Mbps up/down. But dont know why today is become 100Mbps only, and i try connect directl...
BeyondSeek
Jan 14, 2020Aspirant
Hi , sorry for late reply @@. Busy work and just back from vacation hehe.
Anyway, my speed from Orbi router still the same 100Mbps only. I was update my FW to v2.5.1.8 already...
The internet provider is in Philippine (Asia). Web : www.convergeict.com/fiberx/fiber-extreme
Plan : XTREME 4500
And my modem as below jpg file. Huawei.
Do you have any idea for it?
Thanks and Regards,
Seek
Plan : XTREME 4500
Thanks and Regards,
Seek
Jan 15, 2020Guru - Experienced User
Your ONT already has a built in router and wifi. This would be a double NAT condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
I recommend option #3.
