marcgroet
Oct 24, 2022Aspirant
ORBI RBR50 adds satellites as devices - not as satellite
Hi, I am adding satellites to my ORBI RBR50 and they are recognised as devices. So they are not recognised as satellites extending the wifi network. Any tips? Thanks, Marc
- Oct 24, 2022
Glad you got it working. Please mark your thread as solved so others will know. Be sure to save off a back up configuration to file for safe keeping. Saves time if a reset is needed.
Enjoy. 📡
Oct 24, 2022Guru - Experienced User
Be sure same FW version is loaded on the RBS as whats on the RBR.
Be sure your using a good quality LAN cable between the modem and router. CAT6 is recommended.
https://kb.netgear.com/31029/Where-should-I-place-my-Orbi-satellite 📡
What channels are you using? Auto? Try Auto and 48 on 5Ghz. Or try setting manual channel 1, 6 or 11 on 2.4Ghz and 40 to 48 channel on 5Ghz.
https://community.netgear.com/t5/Orbi/Most-Stable-Orbi-Configuration/m-p/1941087/highlight/true#M97026
marcgroet wrote:
Hi,
Any tips?
Thanks,
Marc
- marcgroetOct 24, 2022Aspirant
Thanks for all the replies.
I did a complete refresh (incl Orbi RBR50) and now it works (again).
Marc
- FURRYe38Oct 24, 2022Guru - Experienced User
Enjoy. 📡
