zulumike99
Oct 04, 2019Aspirant
Orbi RBR50 and 6acat cable
Hello Netgear Community: The Orbi50 I am using came with a 5e flat wire cable that connects to the cable modem. I plan on upgrading the cable from the computer to the Orbi50 router in my network ...
Oct 04, 2019Guru - Experienced User
CAT6A is large inwall cabling, not meant for patching in between two devices. CAT6 is recommended for patch cables in between LAN devices. CAT6 and 6A is rated for 10Gb speeds, when and if we ever see that. :smileywink:
Some in box lan cables are not made well. I recommend you get good quality LAN cabling from online retailers.
- zulumike99Oct 07, 2019Aspirant
Thanks for your response and for sharing your insights.
