zulumike99
Oct 04, 2019Aspirant
Orbi RBR50 and 6acat cable
Hello Netgear Community: The Orbi50 I am using came with a 5e flat wire cable that connects to the cable modem. I plan on upgrading the cable from the computer to the Orbi50 router in my network ...
CrimpOn
Oct 04, 2019Guru - Experienced User
zulumike99 wrote:Should I also upgrade the Orbi50 cable to the cable modem from 5e to 6a to receive any maximum benefit? Regards, Mike
For the short distance between Orbi and modem, the cable Netgear provided in the box is fine. The cables are simply not long enough for the "special twists" in Cat6 cable to have any effect. On the other hand, Cat6 cables are really inexpensive and come in lots of lengths. I recently got Cat6 cables in 1ft, 2ft, 3ft, 5ft, 7ft, 10ft. and reduced my "cable clutter" a lot by tailoring the cable to the distance it needs to reach.
zulumike99
Oct 07, 2019Aspirant
Thanks a bunch! I certainly will take what you said under serious consideration.
- FURRYe38Oct 07, 2019Guru - Experienced User
Good Luck.
