zulumike99
Oct 04, 2019Aspirant
Orbi RBR50 and 6acat cable
Hello Netgear Community: The Orbi50 I am using came with a 5e flat wire cable that connects to the cable modem. I plan on upgrading the cable from the computer to the Orbi50 router in my network ...
zulumike99
Oct 07, 2019Aspirant
Thanks a bunch! I certainly will take what you said under serious consideration.
Oct 07, 2019Guru - Experienced User
Good Luck.
