tekgeek1
Mar 26, 2020Follower
Orbi RBR50 and FIOS - dropping Internet
Evening, So I recently installed the Orbu RBR50 with 2 sateliite devices - using Verizon FIOS. So I disabled the FIOS AP (killed the wireless) and use the RBR50 as the wireless hub to the 2 sate...
Mar 27, 2020Guru - Experienced User
Modem Combo Units:
This would be a double NAT condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
Try a factory reset and setup from scratch. Power off the ISP FIOS unit for 30 seconds then back on.
https://kb.netgear.com/31486/How-do-I-reset-my-Orbi-system-to-factory-default-settings
