penguinhi
Jul 19, 2020Aspirant
ORBI RBR50 and Optimum Altice Box
Hello all, Yesterday, Optimum gave us and installed a new box called the Altice Modem(?). It provides TV and Internet in one box. I then connected our Orbi RBR50 and two satellites (RBS50) to our ne...
CrimpOn
Jul 19, 2020Guru - Experienced User
If the Orbi is in "router" mode, then nothing must be changed when the Altice is put into bridge mode.
The IP address to be concerned about is on the WAN side of the Orbi.
That IP should be a "public" IP address, not a private one.
- penguinhiJul 19, 2020Aspirant
Thank you for your quick reply!
I see. I have my Orbi rbr50 on "router" mode.
How do I check the IP address on the WAN side of the Orbi? Or is it already automatically configured to be a "public" IP?
Sorry, I am a newbie at this.
- CrimpOnJul 19, 2020Guru - Experienced User
penguinhi wrote:I see. I have my Orbi rbr50 on "router" mode.
The Orbi web interface (http://orbilogin.net) shows this information on the "Internet" menu. The second panel displays the IP address, subnet mask, and gateway IP address. It is also on the Advanced Tab Home screen (right panel).
