Retired_Member
Aug 17, 2024ORBI RBR50 and RBS50 - new satellite required
Hello I have a Netgear RBR50 router + RBS50 satellite. Both work quite well but I need another satellite for coverage purposes. The RBS50 is very hard to find in Australia (maybe Netgear have...
CrimpOn
Aug 17, 2024Guru - Experienced User
Yes, the original Orbi WiFi5 models were introduced in 2016 and are very difficult to find these days, especially since the industry has moved on to WiFi6 four four years ago (and is moving to even newer standards "as we speak").
None of the satellites Netgear lists as compatible with the RBR50 router will result in a significant drop in performance. However, they are ALL becoming hard to find.
There is a good chance that a three-pack of WiFi6 capable mesh units is available for not much more than the cost of a used RBS50 (if you can find one).
Retired_Member
Aug 17, 2024Thanks for the response. Will RBS10 RBS20 RBW30 or RBS40 work without degrading my wifi?
