Gordo88
Jun 14, 2022Aspirant
Orbi RBR50 and RBS50 - satellite is ethernet connected but not talking
I have and RBR50 router setup which is working well. Separately to that, due to the house length and the instability of the Orbi Mesh system around metal surfaces I have an Ethernet connection to the...
CrimpOn
Jun 14, 2022Guru - Experienced User
I tend to believe the web interface over the 'app'.
Does the web interface show any devices connected to the satellite on the Attached Devices page?
- Gordo88Jun 14, 2022Aspirant
No it doesnt, and following reading the issues from many other users I changed to a spare RBS50 I had and resetup the network. Guessing there is corruption in the FW.
System is still not stable which I find very disappointing. Also cannot connect 2.4GHz systems to it or isolate to a 2.4GHz SSID which is a complete pain.
- CrimpOnJun 14, 2022Guru - Experienced User
Were these devices not connected to the Orbi previously? Every time I mess with a WiFi system, or replace it with a new one, I always set the WiFi SSID/password to be exactly what it was before, and all my devices connect automatically.
Since the start (2016) Netgear's Orbi has never supported having different SSID's for the 2.4G and 5G WiFi. There was a hack that was discovered to do so, but it quit working years ago.
- KevinLiTJun 14, 2022NETGEAR Moderator
Hello Gordo88,
Welcome to the NETGEAR Community!!!
Please check your PM.
Best,
Kevin
Community Team
