combatpantz
Apr 05, 2020Guide
orbi rbr50 and rbs50, satellite problems
Hi there, Sorry if the following does not make sense, this is my first post. I have a Orbi rbr/rbs50 set up, with the satellite hardwired to the router, which had been working fine untill a couple...
- Apr 21, 2020
Update
All has been well since my last post, cheers for all the responses.
Adrian
combatpantz
Apr 10, 2020Guide
Update
Still all the same as yesterday, with no problems of connecting to net, RBR or RBS. although still not showing all devices connected but they are.
I did some further diagnosis on my system, and with the limited knowledge i have.
The IP addresses on the computers and are all showing dynamic.
I am showing double NAT, so i will get on to my IPS to try rectify this. (I can not remove Sagamcom gateway F@ST 3864AC NBN as it prvides my home phone through it). Although i suspect i have had double NAT for years and i have had no problems with the set up till the other day.
Will update again after talking to IPS provider.
Again thanks for the responses.
Cheers
Adrian
combatpantz
Apr 21, 2020Guide
Update
Adrian
