Ph0t0bug
Mar 05, 2021Tutor
Orbi RBR50 and Spectrum - having strange issues.
To start here is the setup: Orbi -RBR50 w/1-sat. Updated to the latest Firmware Spectrum Device: E31N2V1 modem only updated to the latest Firmware (VOIP in modem but not used and the light does not...
Mar 06, 2021Guru - Experienced User
Did you disable uPnP on the RBR before setting up any port forwarding configurations?
What FW version are you using?
Has this configuration ever worked for you?
vajim
Mar 06, 2021Master
perhaps this will help:
https://kb.netgear.com/31069/How-do-I-configure-port-forwarding-on-my-Orbi-system
- Ph0t0bugMar 08, 2021Tutor
Yea... did all that. Both individually for each port and again with the ports with commas.. neither seemed to work.
