Ph0t0bug
Mar 05, 2021Tutor
Orbi RBR50 and Spectrum - having strange issues.
To start here is the setup: Orbi -RBR50 w/1-sat. Updated to the latest Firmware Spectrum Device: E31N2V1 modem only updated to the latest Firmware (VOIP in modem but not used and the light does not...
Ph0t0bug
Mar 08, 2021Tutor
Did you disable uPnP on the RBR before setting up any port forwarding configurations?
A: No, after disabling it and configuring can I turn it back on? The guy who is using the system really needs it to be on.
What FW version are you using?
A: The latest the update tab checks: Ver. 1.1.0.16
Has this configuration ever worked for you?
A: It did with another router. I believe it was the Nighthawk Router.
Ph0t0bug
Apr 22, 2021Tutor
I just found a page that says the latest Firmware is above 2.0 while the orbi its self is set for auto updates but still has the 1.1.0.16 version... what *IS* the latest version...(sigh)
