tiki-monster
Jun 23, 2021Aspirant
Orbi RBR50 asking for Password and Security Question that I never set up
Recently, upgraded (re-signed) Spectrum wifi, and they actually said I don't really need to rent the Spectrum router, and just plug into my Orbi router. Which I did, and it worked. Until certain si...
- Jun 23, 2021
tiki-monster wrote:How do I bypass this problem? Do I just hit reset?
A Factory Reset returns the Orbi to factory default settings:
- The WiFi SSID/password are set to the values on the product label (bottom of the case)
- The web browser administrative credentials are "admin" (which cannot be changed) and "password".
https://www.youtube.com/watch?v=cMw4ePACgc4
Open a web browser (Safari, Chrome) to http://orbilogin.net. Enter "admin" and "password" to set up the router.
During setup, there will ba a page where you can choose the security questions to unlock the router if the admin password is entered incorrectly three times in a row.
Jun 23, 2021Guru - Experienced User
tiki-monster wrote:Recently, upgraded (re-signed) Spectrum wifi, and they actually said I don't really need to rent the Spectrum router, and just plug into my Orbi router. Which I did, and it worked. Until certain sites start to ask for IDs and Passwords. I've owned the Orbi RBR50 for a few years, don't recall setting anything up, and nothing I entered matched.
When I entered the serial number of the machine, it matched, and further went into more security questions that I didn't set up.
I'm using Macs and iPhones in this household, and I have no access to a PC, just Macs.
Orbi RBR50 with 2 satellites. One Mac is plugged directly into the router.
Thanks in advance.
- tiki-monsterJun 24, 2021Aspirant
Currently, I'm only using the Spectrum internet's modem. It is Model ET2251. Outside of the box, it just said Spectrum. Not sure who made it for them. Charter Communications (Spectrum).
- CrimpOnJun 24, 2021Guru - Experienced User
My recommendation is to unbend the paperclip, stick it into the Reset hole until the Power LED begins to flash amber, pull out the paperclip and then wait 2-3 minutes for the Orbi router to power up and connect.
In just under 3 minutes, the Ring light at the top of the modem should turn blue for a minute or so, and the Orbi should be "live".
Connect to the Orbi WiFi using the SSID/password printed on the product label (bottom of the case). You should be "good to go".
Or, connect a computer to the Orbi with an ethernet cable.
If you are not happy using the default WiFi credentials, open a web browser and connect to http://orbilogin.net or http://192.168.1.1
The login credentials will be "admin" (which cannot be changed) and "password", which the router will prompt you to change.
Sorry. I did not get the notice that the problem is resolved until after I sent the last message.
"My Bad"
