ClaudeTiger's avatar
ClaudeTiger
Orbi RBR50 Assigning static ip to device
Trying to assign a static ip address to a device (Hubitat Elevation C-5 home automation hub) per instructions of the device manufacturer.  The device does not have the capability to do this itself.  I go to LAN Setup and Add the device information and the desired IP address (within the DCHP range) and hit Apply.  Despite reboot, the device retains the original dynamically-assigned IP address.
The manual talks about assigning static addresses to computers and servers, but I cannot find a reference to devices.  Is this within the capability of this particular router?
Thanks for your assistance.
  • If you see the ip in the static ip list already after the orbi rebooted make sure you reboot the device needing the static ip.
  • FURRYe38's avatar
    Please post about this over in the main Orbi forum:
    https://community.netgear.com/t5/Orbi/bd-p/Orbi
    Thank you.
