cc1130
Mar 29, 2019Aspirant
Orbi RBR50, ATT&T Pace, Sonos Connection Issue
Hello,
I am hoping someone can help me with this. I have an ATT Pace router/moden connected to my Orbi Router RBR50. When I use the Orbi under router operation mode, my Sonos works fine but I am n...
Mar 29, 2019Guru - Experienced User
When you have your Orbi in router mode have you switched your AT&T pace over to bridged mode? I didn't see (i've missed stuff before) a model for the att pace but check your manual to see if there's a setting for bridged or modem only mode. You could be running into a double NAT situation.
- Chuck_MMar 30, 2019Mentor
How many Sonos devices (including bridges) are HARD WIRED into your network?
The other question above of is your original modem/router bridged with WIFI TURNED OFF when Orbi is in the Router mode?
- cc1130Mar 30, 2019Aspirant
Hello,
I only have one Sonos speaker operating on wi-fi.
I did turn off the WIFI for both 2.4 and 5ghz on the ATT modem/router model 5268AC, not sure how to switch the ATT modem/router to bridge mode.
Hello,
I am not sure on how to set to bridge mode, I am not well versed in configuring wi-fi. I have the 5268AC model and it serves as a router/modem. Can you let me know how I would be able to turn on bridge mode? I read somewhere that ATT modem/router's do not support bridge mode?
