cc1130
Mar 29, 2019Aspirant
Orbi RBR50, ATT&T Pace, Sonos Connection Issue
Hello,
I am hoping someone can help me with this. I have an ATT Pace router/moden connected to my Orbi Router RBR50. When I use the Orbi under router operation mode, my Sonos works fine but I am n...
Mar 30, 2019Guru - Experienced User
What FW is currently loaded?
Modem Combo Units:
Couple of options,
1. Configure the modem for transparent bridge mode. Then use the Orbi router in router mode. You'll need to contact the ISP for help and information in regards to the modem being bridged correctly.
2. If you can't bridge the modem, disable ALL wifi radios on the modem, configure the modems DMZ or IP Pass-Through for the IP address the Orbi router gets from the modem. Then you can use the Orbi router in Router mode.
3. Or disable all wifi radios on the modem leaving it in router mode and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
cc1130 wrote:
Hello,
I am hoping someone can help me with this. I have an ATT Pace router/moden connected to my Orbi Router RBR50. When I use the Orbi under router operation mode, my Sonos works fine but I am not able to dowload or access the Apple App Store. I've already tried changing the Orbi to function in Access Point mode which solves that problem, but then I can't use my Sonos One.
It seems that once one problem is solved, the other arises. I currently have my Orbi mesh network with two Satellites in the house and they work fine.
Is there a way to configure the Orbi as a Router mode and overcome the issue with not being able to use the Apple App Store, Netflix, and etc.? That way my Sonos can work, because I am having no luck with my Sonos with my Orbi on Access Point mode. I only have one Sonos speaker and do not want to use a boost or sonosnet ( there is really no need for it since I only have speaker). I've tried everything, even changed the channel for 2.4ghz to channel 1 instead of having it on auto. So far, the only way my Sonos will work is if the Orbi is on Router mode ( I did change the 2.4ghz to channel 1 and the sonos will work for Pandora but not Spotify - says error playing queue 701). Im almost certain there is a way to configure everything to work seamlessly but I just dont know how, can anyone help me on this?
