cc1130
Mar 29, 2019Aspirant
Orbi RBR50, ATT&T Pace, Sonos Connection Issue
Hello,
I am hoping someone can help me with this. I have an ATT Pace router/moden connected to my Orbi Router RBR50. When I use the Orbi under router operation mode, my Sonos works fine but I am n...
cc1130
Mar 30, 2019Aspirant
Hello,
Sorry, not sure what FW stands for. I am not familiar with configuring wi-fi settings. Most of the time I just have the ISP set everything up for me but they have not helped me at all with these issues.
How do I do this:
2. If you can't bridge the modem, disable ALL wifi radios on the modem, configure the modems DMZ or IP Pass-Through for the IP address the Orbi router gets from the modem. Then you can use the Orbi router in Router mode.
I have access to the admin for my ATT router, I just don't know how to configure DMZ or IP Pass-Through. Is the IP address the Orbi Router gets from the modem on the side of my ATT modem box?
ekhalil
Mar 30, 2019Master
Please set the ATT router to DMZPlus Mode as follows:
1. Connect a computer to a LAN port on the ATT router and open the gateway home page at http://192.168.1.254.
2. Click the Settings tab, then click the Firewall tab.
3. Click Applications, Pinholes and DMZ.
4. Select the IP address assigned to Orbi.
5. Select Allow all applications (DMZplus mode).
6. Click Save.
6. Click Save.
- cc1130Mar 31, 2019AspirantGreat! That seems simple enough. Sorry for the stupid question, but how do I figure out which IP address is assigned to the Orbi?
Great! That seems simple enough. Sorry for the stupid question, but how do I figure out which IP address is assigned to the Orbi?- FURRYe38Apr 01, 2019Guru - Experienced User
Look on the modems web page under connected clients. You should see it there. I would do a IP address reservation on the modem for the Orbi so the address doesn't change.
cc1130 wrote:
Great! That seems simple enough. Sorry for the stupid question, but how do I figure out which IP address is assigned to the Orbi? - ekhalilApr 01, 2019Master
cc1130 wrote:
Great! That seems simple enough. Sorry for the stupid question, but how do I figure out which IP address is assigned to the Orbi?When you click on "Applications, Pinholes and DMZ" you should see a list of all connected devices to the ATT Router, they should not be many, the Orbi IP address should be marked as Orbi or Netgear, I think you should be able to identify it easily in the list!
- Blanca_OMay 08, 2019NETGEAR Employee Retired
Hi cc1130
We’d greatly appreciate hearing your feedback letting us know if the information provided to you has helped resolve your issue or if you need further
assistance.
If issue still not resolved, please check your inbox.
Blanca
Community Team- Dgr8wunMay 18, 2019Aspirant
Hi, did you get this resolved? I have the same problem. Orbi is set on AP mode with 2.4 on channel 11. only Pandora works, AppleMusic and Amazon doesnt.
