cc1130
Mar 29, 2019Aspirant
Orbi RBR50, ATT&T Pace, Sonos Connection Issue
Hello,
I am hoping someone can help me with this. I have an ATT Pace router/moden connected to my Orbi Router RBR50. When I use the Orbi under router operation mode, my Sonos works fine but I am n...
cc1130
Mar 30, 2019Aspirant
Hello,
Sorry, not sure what FW stands for. I am not familiar with configuring wi-fi settings. Most of the time I just have the ISP set everything up for me but they have not helped me at all with these issues.
How do I do this:
2. If you can't bridge the modem, disable ALL wifi radios on the modem, configure the modems DMZ or IP Pass-Through for the IP address the Orbi router gets from the modem. Then you can use the Orbi router in Router mode.
I have access to the admin for my ATT router, I just don't know how to configure DMZ or IP Pass-Through. Is the IP address the Orbi Router gets from the modem on the side of my ATT modem box?
Mar 31, 2019Guru - Experienced User
FW = Firmware. Just checking to see what version you have installed.
Let us know if the suggestions help. If you can't seem to get the ISP modem correctly configured for DMZ or IP Passthrough, You might contact the ISP and have them help you. Or configure the Orbi system for AP mode as suggested in option #3.
cc1130 wrote:
Hello,
How do I do this:
