cc1130
Mar 29, 2019Aspirant
Orbi RBR50, ATT&T Pace, Sonos Connection Issue
Hello,
I am hoping someone can help me with this. I have an ATT Pace router/moden connected to my Orbi Router RBR50. When I use the Orbi under router operation mode, my Sonos works fine but I am n...
cc1130
Apr 01, 2019Aspirant
Great! That seems simple enough. Sorry for the stupid question, but how do I figure out which IP address is assigned to the Orbi?
Blanca_O
May 09, 2019NETGEAR Employee Retired
Hi cc1130
We’d greatly appreciate hearing your feedback letting us know if the information provided to you has helped resolve your issue or if you need further
assistance.
If issue still not resolved, please check your inbox.
Blanca
Community Team
- Dgr8wunMay 18, 2019Aspirant
Hi, did you get this resolved? I have the same problem. Orbi is set on AP mode with 2.4 on channel 11. only Pandora works, AppleMusic and Amazon doesnt.
- FURRYe38May 20, 2019Guru - Experienced User
Is the Orbi system operating in Router or AP mode?1. Configure the modem for transparent bridge mode. Then use the Orbi router in router mode. You'll need to contact the ISP for help and information in regards to the modem being bridged correctly.
2. If you can't bridge the modem, disable ALL wifi radios on the modem, configure the modems DMZ or IP Pass-Through for the IP address the Orbi router gets from the modem. Then you can use the Orbi router in Router mode.
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
- gr8shoMay 20, 2019Virtuoso
If you're using a Pace 5268AC in front of the Orbi, you'll likely be less frustrated getting it switched to a BGW210 gateway box.
