cc1130
Mar 29, 2019Aspirant
Orbi RBR50, ATT&T Pace, Sonos Connection Issue
Hello,
I am hoping someone can help me with this. I have an ATT Pace router/moden connected to my Orbi Router RBR50. When I use the Orbi under router operation mode, my Sonos works fine but I am n...
Dgr8wun
May 18, 2019Aspirant
Hi, did you get this resolved? I have the same problem. Orbi is set on AP mode with 2.4 on channel 11. only Pandora works, AppleMusic and Amazon doesnt.
May 20, 2019Guru - Experienced User
Is the Orbi system operating in Router or AP mode?
1. Configure the modem for transparent bridge mode. Then use the Orbi router in router mode. You'll need to contact the ISP for help and information in regards to the modem being bridged correctly.
2. If you can't bridge the modem, disable ALL wifi radios on the modem, configure the modems DMZ or IP Pass-Through for the IP address the Orbi router gets from the modem. Then you can use the Orbi router in Router mode.
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
