cc1130
Mar 29, 2019Aspirant
Orbi RBR50, ATT&T Pace, Sonos Connection Issue
Hello,
I am hoping someone can help me with this. I have an ATT Pace router/moden connected to my Orbi Router RBR50. When I use the Orbi under router operation mode, my Sonos works fine but I am n...
Dgr8wun
May 18, 2019Aspirant
Hi, did you get this resolved? I have the same problem. Orbi is set on AP mode with 2.4 on channel 11. only Pandora works, AppleMusic and Amazon doesnt.
gr8sho
May 20, 2019Virtuoso
If you're using a Pace 5268AC in front of the Orbi, you'll likely be less frustrated getting it switched to a BGW210 gateway box.
