Geezynz
Jan 31, 2020Aspirant
Orbi RBR50 backhaul always disconnected
Hello - I'm getting strange responses from my orbi login page, for a weeks now my two satalites are always listed as BACKHAUL DISCONNECTED, and also under attachd devices, almost always nothing is li...
Jan 31, 2020Guru - Experienced User
Are RBS wireless or wire connected to RBR?
Armor, Circle, Daisy Chain, Fast Roaming, IPv6 and Set 20/40Mhz Coexistence to 40Mhz only. Save settings and reboot the router and satellite(s).
I recommend you manually download v2.5.1.8 and update the RBSs first then RBR lastly:
