Grandmstrbud
Jan 12, 2020Aspirant
Orbi RBR50 bandwidth control
I have a 1GB fiber connection both ways. When I first set this up I got the speeds I should but it seems after a while devices drop to getting 200/200 each way whether hard wired or on wireless. If I...
Grandmstrbud
I do turn off the traffic meter but I do have the access control on even though for some reason it doesn't work on all sites. I put in 3 so far and only 1 is blocked.
Jan 12, 2020Guru - Experienced User
Be sure to setup IP address reservations for devices you put in the access control list if you use it.
- GrandmstrbudJan 12, 2020Aspirant
I have a few devices that have reservation but I have the access control list turned off now to see if that speeds it up. So far it hasn't. Hopefully they will fix this I really like how well it works but if it slows down this much I may have to rethink having this setup. I should be getting 800/800 plus on a wired connection all the time.
- FURRYe38Jan 13, 2020Guru - Experienced User
I think once access controls are enabled, and then disabled, this won't fix the speed issue. You'll need to factory reset the RBR and setup from scratch again. This time, don't enable Traffic Meter or Access Controls.
- GrandmstrbudJan 13, 2020AspirantI think I'll return it before I factory reset it and set it up from scratch. It took me to long to get it configured the way I want it and my devices named and what not. I'll call Netgear support but my guess is they won't be any help
