clubshred's avatar
Mar 26, 2018
Orbi RBR50 Basic screen, unable to see satellites and attached devides online
I logged in to see to check for updates and noticed that on the Basic home page attached devices, no satellites or attached devices are shown. Normally I have 3 satellites and 33 attached devices. Why are they not shown? No router updates were done, only IOS update for my iPAD and it does show 3 satellites but no attached devices. I have rebooted my PC and my iPAD and no change at all. Any thoughts or help would be greatly appreciated.
RBR50 Router
3x RBS50 satellites
current firmware version V2.1.2.18 on all Orbi devices
PC running Windows 10
iPAD running 11.2.6
  • DarrenM's avatar
    DarrenM
    Sr. NETGEAR Moderator
    Have you checked this with both the app and the web gui to see if it maybe a display issue?
    DarrenM
    • clubshred's avatar
      clubshred
      Tutor
      Thank you for help!!
      I have heard that Windows 10 can sometimes be an issue with certain programs. I remember there was a remedy for that in the display properties. I will try and if it fixes it but I think it would affect the whole program and not just a single item within the GUI.
      But you never know, but I will try.
      Thank you again!!
  • You might try updateing to the Beta FW and see if this changes anything.
      clubshred
      Tutor
      Thank you for your reply, however I’m not sure what a Beta FW is and how do I find it and or configure it?
      Thank you again!
