Dar1
Aug 25, 2021Follower
Orbi RBR50 blocked WiFi to my sump pump monitor
I use something called PumpSpy to monitor the operation of a sump pump at our house. It uses WiFi to report to me and has never been a problem but last night orbi blocked it and continued to send bloc...
Aug 27, 2021Guru - Experienced User
Is Armor enabled by chance, if so, disable it.
Dar1 wrote:
I use something called PumpSpy to monitor the operation of a sump pump at our house. It uses WiFi to report to me and has never been a problem but last night orbi blocked it and continued to send blocked messages every minute for hours overnight. There is no way to “mass unblock” and it appears that simply unblocking one of the notifications doesn’t prevent the next block from occurring. I’m order to keep my sump pump monitor online, I’ve had to disable security all together. Is there any way to permanently white list this device beyond what I’ve tried? Net gear gives me no options for continued support so hoping this community can help. Thanks!
