JGJ
Feb 26, 2020Aspirant
Orbi RBR50 blocking my VoiP from registering.
I have a VoIP grandstream telephone. I have had this for about a year with no connectivity issues. Recently however my orbi has not allowed the phone to register with the VoIP which this has rendered...
Feb 26, 2020Guru - Experienced User
What happens if you put the VoIP phone into the RBRs DMZ? Under Advanced/Setup/WAN Setup
- JGJFeb 28, 2020AspirantOK yes thank you for assistance but wow way over my head I'm sorry
- CrimpOnFeb 28, 2020Guru - Experienced User
JGJ wrote:
OK yes thank you for assistance but wow way over my head I'm sorryIt is understandably upsetting when two systems have worked together for over a year and suddenly no longer work together.
- Does anything else in the house no longer work as it should?
- How do you manage the Orbi (web interface or Orbi "app")?
- Have you done a "reset" on everything. i.e. unplug them all, plug in the modem. After the modem "settles down", plug in the Orbi. Ofter the Orbi settles down, plug in the phone? (I know this sounds "lame", but back in the early days of IBM PC's, we fixed a lot of problems with the "big red (power) switch".)
