JGJ
Feb 26, 2020Aspirant
Orbi RBR50 blocking my VoiP from registering.
I have a VoIP grandstream telephone. I have had this for about a year with no connectivity issues. Recently however my orbi has not allowed the phone to register with the VoIP which this has rendered...
CrimpOn
Feb 26, 2020Guru - Experienced User
JGJ wrote:I have a VoIP grandstream telephone. I have had this for about a year with no connectivity issues. Recently however my orbi has not allowed the phone to register with the VoIP which this has rendered the phone now inoperable.
Could you please clarify the situation:
- The Grandstream has been working with this Orbi for a year with no issues, or
- The Grandstream was working with a different system for a year, and does not work with a new Orbi installation?
Thanks
- JGJFeb 28, 2020AspirantMy Orbi and my grand stream have both been working together for the last year. Something recently changed in the Orby to not allow the grand stream to work I don't know what that was. My VoIP technical support could not see that it was anything to do with the phone. Because what we did is we took the phone LAN Line and plug that directly into the modem and the phone worked. So clearly it's something with the router
- FURRYe38Feb 28, 2020Guru - Experienced User
What is the Mfr and model# of the ISP modem the NG router is connected too?What happens if you put the VoIP phone into the RBRs DMZ? Under Advanced/Setup/WAN Setup
