kb0wwp
Feb 10, 2022Aspirant
Orbi RBR50 bricked - anything I can do?
 Last night my network went down.  After some troubleshooting I found that the Orbi router was unresponsive.  But what was unusual is there was no flashing light on top.  That's usually my first clue ...
Feb 10, 2022Guru - Experienced User
https://kb.netgear.com/000059634/How-to-upload-firmware-to-a-NETGEAR-router-using-Windows-TFTP
Need to press the reset button for 30 seconds then release, then it send to PUT the command and upload the FW.
Make sure you enable tftp: https://www.thewindowsclub.com/enable-tftp-windows-10
Video walk through using a tftp client. Use the built in one for windows 10 though. the video is more of an example of how its done:
https://www.youtube.com/watch?v=R9DLrLQrpaw
I had a problem on a Windows 10 PC where this didn't work to use TFTP, so I switched to a WIndows 7 PC and the TFTP worked.
Mac TFTP: https://www.petenetlive.com/KB/Article/0001247
Try nmrpflash:
https://github.com/jclehner/nmrpflash
If any of this fails, the RBR needs to be replaced.
kb0wwp
Is this a bot? Because everything you suggested I already said I tried and didn't work. :)
I guess "throw it away" is my last option. Too bad.
- plemansFeb 10, 2022Guru - Experienced UserYou tried nmrpflash? I've seen that work when tftp wouldn't And you can try forcing an earlier firmware to it incase that was the issue. another thing you can try is swapping the power supply from one of the satellites to the router. Maybe the power supply is faulty and isn't letting it fully boot - kb0wwpFeb 10, 2022AspirantNo connection to the Orbi is possible - wireless or with a network cable. I've tried multiple computers and all say "network cable unplugged". I have tried a different power adapter. I remember decades ago having to use a "crossover cable" in situations. Is that still a thing, or needed in this case? - plemansFeb 10, 2022Guru - Experienced UserWhen theirs corrupt firmware/bootup issues, thats what you expect. If you follow the guide for nmrpflash, it has you set a static ip address on the computer and try putting the router in a recovery state. It isn't going to show up like you expect.
