Retired_Member
Sep 25, 2019Orbi RBR50 bricked during update to 2.3.5.30
Router was on firmware 2.3.1.60. I downloaded the latest firmware update, 2.3.5.30, and via Ethernet cable. Router was performing the update and got stuck for a very long time. The router was unrespon...
Retired_Member
Sep 25, 2019RBR50 is not responding to anything so I can't even go back to the previous firmware. The green power light is steady solid.
Sep 25, 2019Guru - Experienced User
And pressing the reset button for only 15 seconds doesn't result in any top ring LED coming on?
- Retired_MemberSep 25, 2019
FURRYe38 wrote:And pressing the reset button for only 15 seconds doesn't result in any top ring LED coming on?
Nope...no ring light at all. The power ON green light remains green. Seems like the router is not communicating and not responding to any commands.
