Retired_Member
Sep 25, 2019Orbi RBR50 bricked during update to 2.3.5.30
Router was on firmware 2.3.1.60. I downloaded the latest firmware update, 2.3.5.30, and via Ethernet cable. Router was performing the update and got stuck for a very long time. The router was unrespon...
Retired_Member
Sep 25, 2019
I guess you won't be doing any manual updates again...??
Possibly step the FW back? With those numbers I can't tell if you went back or forward. Good luck.
Retired_Member
Sep 25, 2019
I am unable to proceed forward or even go back to the original firmware.
