Retired_Member
Sep 25, 2019Orbi RBR50 bricked during update to 2.3.5.30
Router was on firmware 2.3.1.60. I downloaded the latest firmware update, 2.3.5.30, and via Ethernet cable. Router was performing the update and got stuck for a very long time. The router was unrespon...
Sep 25, 2019Guru - Experienced User
Did you use Windows built in TFTP or NGs TFTP program?
Retired_Member wrote:
Router was on firmware 2.3.1.60. I downloaded the latest firmware update, 2.3.5.30, and via Ethernet cable. Router was performing the update and got stuck for a very long time. The router was unresponsive. The power green light is solid and no ring light on top. Unable to get router into recovery mode...green light stays solid green.
I tried hard reset and it was unresponsive as well. Tried 30-30-30 and no luck. Unable to perform TFTP because when I plugged one end to PC and other end to RBR50 the computer doesn't recognize it's plugged in to a router or network. The network icon has an X.
Tried this method and it doesn't work either. https://kb.netgear.com/000059634/How-to-upload-firmware-to-a-NETGEAR-router-using-Windows-TFTP
Ran out of options already. Router is out of warranty so no RMA. This is a solid brick???
Retired_Member
Sep 25, 2019
FURRYe38 wrote:Did you use Windows built in TFTP or NGs TFTP program?
I actually tried both Windows TFTP and NG TFTP. There is no response from the router.
