Retired_Member
Sep 25, 2019Orbi RBR50 bricked during update to 2.3.5.30
Router was on firmware 2.3.1.60. I downloaded the latest firmware update, 2.3.5.30, and via Ethernet cable. Router was performing the update and got stuck for a very long time. The router was unrespon...
CrimpOn
Sep 25, 2019Guru - Experienced User
Retired_Member wrote:
Ran out of options already. Router is out of warranty so no RMA. This is a solid brick???
If the regular factory reset process doesn't work, @michaelkenward described an undocumented way to get an Orbi to factory reset:
Press paperclip in reset hole for 30 seconds
Keep pressing paperclip while removing power
Keep pressing paperclip for another 30 seconds while apply power
Is this the 30-30-30 that people speak of? If so, "My Bad"
Retired_Member
Sep 25, 2019
Ran out of options already. Router is out of warranty so no RMA. This is a solid brick???If the regular factory reset process doesn't work, @michaelkenward described an undocumented way to get an Orbi to factory reset:
Thanks for your input though...yes this is the 30-30-30 method that people mentioned on other threads. Done it and nothing happens.
