Retired_Member
Sep 25, 2019Orbi RBR50 bricked during update to 2.3.5.30
Router was on firmware 2.3.1.60. I downloaded the latest firmware update, 2.3.5.30, and via Ethernet cable. Router was performing the update and got stuck for a very long time. The router was unrespon...
Retired_Member
Sep 25, 2019
ekhalil wrote:
Retired_Member wrote:
Router was on firmware 2.3.1.60. .....Are you sure that the Router was on 2.3.1.60? When was the last time you updated the Router? If you were on 2.1.x.x then you needed a stepping stone (2.2.1.210) to go to 2.3.5.30, this can be a possible reason for the "hanging status" that you're seeing.
Yes, I am 100% sure my router was on 2.3.1.60 because I read the important part of the firmware update before I proceeded with the router. I even double checked to the current firmware yesterday.
Sep 26, 2019Guru - Experienced User
Seems that the RBR is just bricked. :smileysad:
- Retired_MemberSep 26, 2019
FURRYe38 wrote:Seems that the RBR is just bricked. :smileysad:
Thanks for suggestions. I guess it's bricked. Time to look for a new router.
- FURRYe38Sep 27, 2019Guru - Experienced User
Might see if Amazon or eBay have some used ones if you still want to keep with Orbi.
Good Luck.
