Retired_Member
Sep 25, 2019Orbi RBR50 bricked during update to 2.3.5.30
Router was on firmware 2.3.1.60. I downloaded the latest firmware update, 2.3.5.30, and via Ethernet cable. Router was performing the update and got stuck for a very long time. The router was unrespon...
Lucas88
Apr 19, 2020Aspirant
I have had the same problem with my RBR50.I tried everything :30/30/30 reset, TFTP client...nothing worked. I noticed one thing :
Every time I pushed the reset button with the pin and connected the power, the power LED turn solid green,then solid red( which means the firmware is corrupted) and flashing red 7 times and solid green after that.
Does it mean my RBR50 totally bricked ?
Any suggests?
Apr 20, 2020Guru - Experienced User
I would contact NG support to see what your options are.
Lucas88 wrote:I have had the same problem with my RBR50.I tried everything :30/30/30 reset, TFTP client...nothing worked. I noticed one thing :
Any suggests?
- Retired_MemberApr 20, 2020
what changed between message 16 to 19???
