Retired_Member
Sep 25, 2019Orbi RBR50 bricked during update to 2.3.5.30
Router was on firmware 2.3.1.60. I downloaded the latest firmware update, 2.3.5.30, and via Ethernet cable. Router was performing the update and got stuck for a very long time. The router was unrespon...
Lucas88
Apr 21, 2020Aspirant
so... what is the point to have your RBR50 updated? To my understanding, the updates are supposed to fix the problems, not to create the problems. NETGEAR should have some way to unbrick the RBR50 or a secure method to update the firmware.
I have been with NetGear since WNDR3700 to NighthawkAC1900. I never had any problems before, but RBR50. I think it is time I should try some other brands.
Apr 21, 2020Guru - Experienced User
The best way to do updates is to do manual download of FW files from NGs support site. Use a wired PC and connect it directly to the RBS and update the RBS first then connect to the RBR and load the FW lastly on the RBR using the unpacked .zip FW files. Use IE11, Firefox or Opera to do the updates thru the RBSs/RBRs web pages. Theres been some bad experiences coming from users using the auto update FW feature on the RBRs web page. Use the manual method seen on the FW update feature page.
I recommend after the RBS and RBR are updated, factory reset the system and setup from scratch. Been doing this way for a long time. Have not bricked any of my routers or satellites using this process. Works well and is a safest method.
Some of us use this method ourselves.
New FW seems to be fixing problems:
https://community.netgear.com/t5/Orbi/RBR50-RBS50-Firmware-2-5-1-16-Update/m-p/1898060#M89482
Most problems are not FW related.
Overall, its up to you to update FW and your choice too. It's best to review the release notes as well and make the decision to update. It's your system. Use it how you see fit.
You can try Voxels FW for Orbi:
https://community.netgear.com/t5/Orbi/Voxels-FW-available-for-50-series-Orbi-only-available/m-p/1883615#
You can revert back to stock FW if it doesn't work out for you.
Lucas88 wrote:so... what is the point to have your RBR50 updated? To my understanding, the updates are supposed to fix the problems, not to create the problems. NETGEAR should have some way to unbrick the RBR50 or a secure method to update the firmware.
- Retired_MemberApr 21, 2020
Bad advice
The best way to do updates to NOT to do manual updates at all. When there are critical updates for your system, NG will push them automatically to the user. No action required.
- BoilerPlateApr 21, 2020Apprentice
The ony bad advice is the ones given by VAJim. Please avoid his posts. Not helpful, valid or truthful.
Had a long history of trolling and badgering users.
BoilerPlate wrote:The ony bad advice is the ones given by VAJim. Please avoid his posts. Not helpful, valid or truthful.
and what do you call yourself doing....??
